Discussion in "Project Help" started by    sifirsekiz    Dec 12, 2018.
Wed Dec 12 2018, 07:20 pm
Hi guys
I have max30100 pulse sensor
need to measure the pulse using the sensor seeing lcd beat but max30100 using ı2c
https://datasheets.maximintegrated.com/en/ds/MAX30100.pdf Datasheed max30100
can you help me? Circuit diagram and source c codes
Thu Dec 13 2018, 10:01 pm
Fri Dec 14 2018, 10:51 pm
Guys pleaseeee 🙏🏻
Sat Dec 15 2018, 05:24 am
Hi
Members can supply code and diagrams if they want to, but it is not common.
The best way would be for you to find a similar project on the web.
If you have to do it yourself, look at these tutorials about using I2C.
http://www.8051projects.net/wiki/I2C_Implementation_on_8051
http://www.8051projects.net/wiki/DS1307_I2C_RTC_Interfacing_Tutorial
Once you can use I2C we can help you add the Max30100
to a basic 8051 and LCD board.
 sifirsekiz like this.
Sat Dec 15 2018, 02:26 pm
Hi
Yes please help me
Sat Dec 15 2018, 02:32 pm
and ı have pulse sensor one out but anolog use 8051 and LCD board
Can you programming for me
https://pulsesensor.com/products/pulse-sensor-amped
[ Edited Sat Dec 15 2018, 02:36 pm ]
Sun Dec 16 2018, 12:31 am
Hi
The pulse-sensor-amped has an analogue output.
The 8051 or AT89s52 does not have an A to D converter, so can't use it.
The max30100 should be okay though.
Do you have any components yet ?
Sun Dec 16 2018, 12:39 am
Hi
I have max30100 at89s52 and lcd board but ı dont have program:(
Mon Dec 17 2018, 04:43 am
Guys pleaseeeee (
Wed Dec 19 2018, 05:45 pm
Nobody knows?
