Discussion in "Project Doubts" started by    Sudhansudeep    Aug 31, 2018.
Thu Sep 06 2018, 06:42 pm
Fri Sep 07 2018, 02:26 am
I don't know what the problem is, I get no errors.
Please make the "Build output " window bigger so that I can see all the compilation messages.
Have you been able to compile any version of the project with any
version of Keil?
Fri Sep 07 2018, 07:08 am
Change the mobile number as [number removed] in the program. Compile it and send me the program and hex file also.
[ Edited Fri Sep 07 2018, 09:50 am ]
Fri Sep 07 2018, 08:29 am
this is the build output message
Fri Sep 07 2018, 10:38 am
The compiler thinks the micro doesn't have enough memory.
You probably selected an 8051.
Change the selected device.
Go into "Project " then "Select Device for target"
Select the AT89C55
If that works, try changing to AT89C52.
Code for the AT89C55 will be okay for this project.
Check your messages, I sent you some files.
[ Edited Fri Sep 07 2018, 12:06 pm ]
HenryLaf
Mon Apr 22 2024, 03:50 pm
bleradrar
Mon Apr 22 2024, 06:38 am
ppu-pro_ka
Sun Apr 21 2024, 07:39 pm
Infewow
Sun Apr 21 2024, 06:30 pm
HumanTak
Sun Apr 21 2024, 12:26 pm
