Discussion in "Embedded GSM Development" started by    mohsin418    May 6, 2014.
Fri May 09 2014, 05:06 pm
I am using hyper terminal in xp , is its causing a mistake? should I use putty or any other telnet based web client etc, now its banging me.. also after error 1, it keeps on giving me error 20 which is "The cache for transmitting TCP data is full", now how to delete the cache and get rid of this mistake?
Fri May 09 2014, 05:12 pm
I do not think hyper terminal has anything to do with this. are you getting CONNECT now? you cannot do a send command before you get that response. Also before each retry, power cycle modem so that no effect from previous AT command should remain.
Fri May 09 2014, 05:24 pm
I am not getting connect , error 20 is the head ache now
Fri May 09 2014, 05:26 pm
after a few seconds it pops close 5 itsself.
Sat May 10 2014, 02:53 am
Have you tried other servers ?
Google may be a special case.
Sat May 10 2014, 06:08 pm
yup tried hotmail and my own local server too but no success
Mon May 12 2014, 10:48 am
I wish I had that module to try out I am not sure what could be causing the problem. It may be wrong format of commands, or order of commands or something related to network. You can try with TCPTest Tool software and set it up as a server on local machine. try to connect using some external PC and then try with modem.
Mon May 12 2014, 05:11 pm
can you please tell me from scratch , the full sequence which must be followed to get the job done, I will check it from beginning, I would be kind f you
p.s can we format the GPRS to set the settings from start? I guess we can?
Tue May 13 2014, 11:01 am
command flow is/should be same as I mentioned in my first post. You need to give commands in the same format and order. I suggest you use "TCP Test tool" software to make your PC as server and try connecting to it (also make sure your PC has public IP for modem to be able to connect).
sanaaaa
Power cycling modem should do the reset of GPRS too.
Wed May 14 2014, 06:25 pm
this is what I am receiving out of all the efforts,Tried tcp test tool, change system but same result
Bobbyerilar
Thu Mar 28 2024, 08:08 am
pb58
Thu Mar 28 2024, 05:54 am
Clarazkafup
Thu Mar 28 2024, 02:24 am
Walterkic
Thu Mar 28 2024, 01:19 am
Davidusawn
Wed Mar 27 2024, 08:30 pm
Richardsop
Tue Mar 26 2024, 10:33 pm
Stevencog
Tue Mar 26 2024, 04:26 pm
Bernardwarge
Tue Mar 26 2024, 11:15 am
