Discussion in "General help Guidance and Discussion" started by    vijay    Oct 28, 2013.
Mon Oct 28 2013, 05:37 pm
Is there any laser printer using which i can directly print my design on PCB within the range of 6000 INR....
Tue Oct 29 2013, 01:09 pm
Check on eBay. You can surely find one
Wed Oct 30 2013, 12:08 pm
i tried but i am not able to find .Can u help????
Wed Oct 30 2013, 10:20 pm
vijay.parmar1992
It is not possible to print the PCB directly on the bare copper clad.
You will have to print the mirror image of PCB artwork on a Photo Paper/OHP Sheet first.
Then the artwork has to be transferred on the copper clad.
When the artwork is transferred on the clad, you will have to etch it.
Have a look at this video for better explanation
http://www.youtube.com/watch?v=wKEe3otWstM
HP LaserJet Pro - P1108 is a printer which lies in the 6k-6.5k range...
Good Luck!
Thu Oct 31 2013, 06:36 am
Dear Vijay, You can hack an inkjet printer to do the job.
 pradhan.rachit like this.
Thu Oct 31 2013, 07:38 am
Amit @ i know this thing is possible..But you know what changes require to hack it??...................which printer we can use???
Thu Oct 31 2013, 12:41 pm
You can use an inkjet printer. U must ensure that copper clad should not have any burrs and it should be neat and clean. Just you have to alter the paper feeding mechanism to feed the copper clad. Use ur own brain, u will succeed and can bring the product in INDIAN market with lesser cost by buying used inkjet printers and altering it. Inkjet printers are losing reputation now a days over laser printers.
Thu Oct 31 2013, 08:32 pm
Thanks amit......Is there any change in cartridge required???
Fri Nov 01 2013, 06:49 am
No.. The cartridge for the paper will work..But make sure that it moves freely on copper clad.
Mon Nov 04 2013, 02:15 pm
yes better way is to hack a Laser printer.... special PCB printer are not in range of a hobbyist... better to hack a normal laser printer... there are many tutorials available on net...
see these links
1
2
utaletxcyw
Wed Apr 17 2024, 10:21 am
