Discussion in "General help Guidance and Discussion" started by    Tanuja    Dec 19, 2007.
Wed Dec 19 2007, 12:48 pm
Hello,
Please help us out.... we r using IR sensor TSOP 1738...
Tell us how to shield it fron 3sides....
Thank you
Wed Dec 19 2007, 03:08 pm
Do not worry about TSOP1738. it has only the front window (the bulgy part) so you need not to worry about covering it from 3 sides. and its dark color prevent it from ambient light.
Wed Dec 19 2007, 03:16 pm
So can we place both the IR sensor and IR led side by side??
Wed Dec 19 2007, 03:52 pm
yes. you can.. can you please explain what actually you are trying to do? placement of sensors sometime depends on actual work to be done.
Wed Dec 19 2007, 04:01 pm
We r doing a project in wich the detector has to detect the signal reflected from an obstacle ...
We ve to place both the IR led and the detector side by side...
wich was causing the detector to detect the signal directly frm the led n not the reflected ones.
our doubt ws hw exactly can we eliminate ths prblm... as the deadline is approaching can u pls suggest some idea..
we read articles wer thy had mentioned of shielding the detector by using alluminium foil..
can u through some light on it...
thanx
Wed Dec 19 2007, 04:20 pm
place IR LED and TSOP at some distance.. keep the face of LED and TSOP in forward direction. there should not be any problem as such.
shielding is needed in special cases where you have many sources of light. here you have only 1 IR LED and one detector so wont be a problem. place them at some distance.. like 4-5cm.
Wed Dec 19 2007, 06:44 pm
try sheilding leds instead of detector...
place detector little in fromt of leds..
use a pvd wire coating or... any other pipe like thing to shield leds..
Wed Dec 19 2007, 11:41 pm
LED gives minimum or close to 0 illumination when looking from the sideways. but just for safety sake if you want you can shield. You can do testing without shield first.. to get a better idea..
 Tanuja like this.
Thu Dec 20 2007, 11:13 am
thanx..... Ya will try it out..... and
what is pvd wire coating ????...
Thu Dec 20 2007, 03:11 pm
sorry!!!
spelled it wrong/...
PVC
 Tanuja like this.
Astorne
Tue Apr 16 2024, 08:52 pm
Williamjaf
Tue Apr 16 2024, 12:25 pm
best_yyPa
Tue Apr 16 2024, 09:42 am
ErnestoExpop
Tue Apr 16 2024, 02:57 am
Jamesclepe
Mon Apr 15 2024, 11:10 am
Aliciaelora
Mon Apr 15 2024, 07:59 am
btaletvpcu
Mon Apr 15 2024, 04:36 am
UbvpwcTib
Mon Apr 15 2024, 03:13 am
