Discussion in "Map Me Support" started by    VR6Pete    Oct 14, 2009.
Thu Feb 18 2010, 08:06 pm
any time, i'm in the UK quite flexable - how do you want to chat? do you need access to my admin map me to see the problem first hand?
As I say, mapxml.php?type=update works, but doing it through the admin section does not...
Sun Feb 21 2010, 06:29 pm
add me to your msn: ajay_bhargav[at] hotmail [dot] com
or tell me any continent chat client you wanna use.
Tue Oct 12 2010, 08:40 pm
I am still unable to import any users into the plugin.
I've removed the plugin / reinstalled
requested a new API key
When I do the mapxml.php?type=update it displays all the records, however it freezes on "Getting a Map information from mapme_location and storing..."
I still get the error 'GClientGeocoder' is undefined in all browsers, however google has a lot of information about that error: http://www.google.co.uk/search?hl=en&q=GClientGeoCoder+is+undefined&meta=
one thing I do notice if I look at the source for the page is that it's loading jquery.js and admin_config.js as one of the very last thing on the page? Could this be causing an issue?
('/e107_admin/credits.php', 'myWindow', 'status = 1, height = 400, width = 300, resizable = 0')" value='Credits' />
			</div>
<br />
</div>
</td>
</tr>
</table>
<div style='text-align:center' class='smalltext'>
Render time: 0.2829 sec, 0.0139 of that for queries. DB queries: 26. Memory Usage: 1,846kB</div>
<script type='text/javascript' src='../../e107_plugins/mapme/jquery.js'>
</script>
<script type='text/javascript' src='../../e107_plugins/mapme/admin_config.js'>
</script>
<script type='text/javascript'>
SyncWithServerTime('1286895847');
       </script>
</body>
</html>
Notice how it appears after my stats.... in the html source code.
I dont use MSN messenger anymore, do you have facebook? or could chat using something else ? I feel I have posted all the information I can give you...
Thanks.
Pete
[ Edited Tue Oct 12 2010, 08:40 pm ]
Wed Oct 13 2010, 01:15 am
fb: ajay_bhargav at hotmail dot com
Wed Oct 13 2010, 04:02 am
Its something in the admin_config.php thats causing the issue.
I uploaded 1.33 to my site, was able to run the import ok - as soon as I uploaded the admin_config.php from the beta zip file you put on the server the import failed with that GClientGeoCoder error.
I decided to view the source of the admin_config.php page from the 1.33 release and had the following in the code at the bottom:
</script>
<script type='text/javascript' src='http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAj0d_SjPaekN2X8qHX60LYxTH9f-XI0CeyBBAItb4GlRg33T5-BTVmfedVdjG8SPp1yttOWMIGwfmDQ'>
</script>
I notice the working version of admin_config.php that it has my google API key, where as the broken version from the beta release you posted doesnt contain that. I looked up that GClientGeoCoder error, and it does relate to the API key.
Hope this is useful to you.
I dont use MSN anymore, so the only means I have to communicate with you is on here.
Thanks.
Pete
Fri Oct 15 2010, 02:34 am
i gave you my fb email. you can contact me there when i am online
