Discussion in "Map Me Support" started by    LondonGman    Aug 17, 2009.
Mon Aug 17 2009, 01:49 am
I run a small club in the UK and would like the start view for the members profile and in the member list to focus on the UK.
I tried modifying “mapconfig.php” to
else{
   $sql->
mySQLresult = @mysql_query("SELECT * FROM ".MPREFIX."gmarkers WHERE user_id='".USERID."';");
   $rows = $sql->
db_Rows();
   if($rows){
      $row = $sql->
db_Fetch();
      $lat = $row['lat'];
      $lng = $row['lng'];
      $zoom = 6;
   } else {
      $lat = 54.00;
      $lng = -4.00;
      $zoom = 4;
As mentioned in
http://www.8051projects.net/forum-t4589.html
but it did not work. Please help
Thanks for the work you done on this plug. Just what I needed and suggest an admin page for making modification to map in future versions.
also how do i alter the size of the map
[ Edited Mon Aug 17 2009, 01:51 am ]
Tue Aug 18 2009, 03:10 pm
well it should have worked.
Thank you for suggestion... I will surely try to make a new release soon.
Tue Aug 18 2009, 05:21 pm
hmm maybe it is because i am using IE8
or maybe Google changed something.
Thanks anyway for your efforts so far.
Tue Aug 18 2009, 05:24 pm
I will do some tests after i make changes to plugin for user to enter default location.
also trying to add Geocoding so that it automatically places marker if location field is entered by user in his/her profile (location must be enabled in extended).
Sat Aug 22 2009, 07:55 pm
else{
   $sql->
   $rows = $sql->
db_Rows();
   if($rows){
      $row = $sql->
db_Fetch();
      $lat = $row['lat'];
      $lng = $row['lng'];
      $zoom = 6;
   } else {
      $lat = 54.00;
      $lng = -4.00;
      $zoom = 4;
LondonGman
This should look like;
else{
   $sql->
   $rows = $sql->
db_Rows();
   if($rows){
      $row = $sql->
db_Fetch();
      $lat = $row['lat'];
      $lng = $row['lng'];
      $zoom = 6;
   } else {
      $lat = 54;
      $lng = -4;
      $zoom = 4;
you cannot use what it probably thinks is a double like that. if you want to specify a decimal number then wrap it in single quotes.
      $lat = '54.749991';
      $lng = '-4.042969';
      $zoom = 4;
To change the size of the maps, open either the map.sc or mapme.sc; whichever you want to change and modify the division's sizes.
<div id='map' style='width:100%; height:400px'>
</div>
I love this plug-in! Thanks! Have fun.
Fri Dec 18 2009, 05:42 pm
doesn't work anyway...
Fri Dec 18 2009, 05:48 pm
Centurio, this is already added in new version.
Try these beta files.
http://www.8051projects.net/Beta/mapme.zip
Fri Dec 18 2009, 06:07 pm
thx - but doesn't work...
i've completely removed prev. mapme v1.3 an installed the version from your link above.
i've entered my api-key, make my settings - after that it hangs at the user location update (see screen)...
[ Edited Fri Dec 18 2009, 06:07 pm ]
Mon Dec 21 2009, 06:11 pm
can you attach the xml generated from link
http://yoursite.com/(plugins_directory)/mapme/mapxml.php?p=update
PM me the file if you feel problem attaching it.
Mon Dec 21 2009, 06:34 pm
if i enter this http://www.chimera-clan.de/e107_plugins/mapme/mapxml.php - this message will be displayed:
"This XML file does not seem to be style-related information. Below is shown the tree view of the document."
here is my mapxml.php attached...
utaletxcyw
Wed Apr 17 2024, 10:21 am
Anthonyvab
Wed Apr 17 2024, 08:48 am
RobertCix
Wed Apr 17 2024, 06:46 am
