Mobile SIM Card Reader
Fri Sep 07 2007, 12:33 am
there is abok on smart card i am downloading 17.11 mb
John Wiley & Sons - Smart Card Handbook - 3rd Edition
Fri Sep 07 2007, 12:56 am
well is smart cards and SIM cards same thing?
I am not sure they are... protocol must be different.. just the shape is same.. what do you say?
Fri Sep 07 2007, 01:11 am
I found something very interesting..
you must take a look..
http://mobileforensics.wordpress.com/tag/sim/
Fri Sep 07 2007, 01:18 am
well is smart cards and SIM cards same thing?Ajay
well i am not sure but programming tech must be same .may be they use different memory location to store specific data like card id , phone book data location ,sms data location etc and while reading / writing we must take care of them
Fri Sep 07 2007, 01:32 am
Best information on SIM Card! wikipedia..
there are many important things explained about SIM cards.. but there is no protocol information
http://en.wikipedia.org/wiki/Subscriber_Identity_Module
Fri Sep 07 2007, 01:38 am
check this
http://www.electronics-lab.com/projects/mcu/002/003.zip
This "SimpleMouse" Smartcardprogrammer can be used to read and write most of all async - Smartcards (Processorcards), including the new "Hornet and +1" DPSC΄s in update and reprogramming mode.
It is jumper-selectable in either Smartmouse or Phoenix Mode (Reset active hi or low) and Jumper selectable for 3.57 and 6 MHz
Fri Sep 07 2007, 05:18 pm
hi i recently know that there is an IC from phillips TDA8003TS which is used to read and write simcard, you can use that IC with a microcontroller to copy a simcard. the IC can be controlled by the standard I2c
http://www.8051projects.info/datasheets/TDA8003TS.pdf
its source is
India: Philips INDIA Ltd, Band Box Building, 2nd floor,
254-D, Dr. Annie Besant Road, Worli, MUMBAI 400 025,
Tel. +91 22 493 8541, Fax. +91 22 493 0966
its source is
