Discussion in "Software" started by    kirangowle    Apr 9, 2013.
Tue Apr 09 2013, 04:31 PM
Hello,
I have proteus 7.6 SP1 version its getting easily installed in Windows 7 32bit OS but not on 64bit.
Please anyone if you have faced this and know any crack for this it will be greatly helpful for me.
Or you can suggest any other version of proteus which can be installed on 64bit OS.
Wed Apr 10 2013, 06:36 AM
Are you getting the error "file open" while patching it using crack????
Wed Apr 10 2013, 09:32 AM
you should be able to run 32-bit version on 64-bit too... Please mention any error if you're getting while installation.
Wed Apr 10 2013, 06:57 PM
Hello,
kirangowle
try this latest.versions ..instade of 7.6v.....
Proteus VSM 8.0 SP0: http://adf.ly/KL1FQ
Proteus VSM 7.10 SP0: http://depositfiles.com/files/cqfpv7zif
Thu Apr 11 2013, 04:21 PM
I am facing error during LXK file execution. I have attached the screen shot also.
 vinayas9 like this.
Thu Apr 11 2013, 07:42 PM
Well i was also getting this kind of error which said something like this "file open and blah blah blah..." and i tried atleast 5 different versions but the error was more of the same "file open blah blah blah.....". What solved problem was running the file as administrator you know the right clicking on the file and then executing it. Worked for me and if it works for you too then cheers and if not then i am for such a long reply.
 kirangowle like this.
Fri Apr 12 2013, 04:20 PM
Thanks atmega8, I ll try your solution get back to you.
Mon Apr 15 2013, 12:36 PM
running in admin mode should solve your problem do share if it did.. also check in task manager if proteus is running in background.
Fri Apr 19 2013, 04:32 PM
I tired with running in admin mode, but it didnt worked it shows same error.
Now i thinking to install OS of 32bit
Sat Apr 20 2013, 07:29 PM
@ kirangowle
the problem should be solved when you run any thing on window7 as an admin
so make it habit on window 7 to run as admin
i give you a simple tip
hope so i will work for you
i do this trick on windows 8
simply installed a proteus on any 32 bit system or even on xp window
now copy a "Labcenter Electronics" into flash drive
now install a proteus on your 64 bit computer or even do not instal it
now place a Labcenter Electronics from flash to your hard drive
path is "C:\Program Files\Labcenter Electronics" for 32 bit window
for 64 bit "C:\Program Files(x86)\Labcenter Electronics"
if folder exist just replace it
i used 7.8 version and i used this method on my PC on which proteus give me error
after that run proteus as an admin now no need of licenses etc
it should work now
if you want proteus 7.8 you can use this
http://www.4shared.com/rar/N-JFGnMj/proteus_78_sp2.html
[ Edited Sat Apr 20 2013, 07:40 PM ]
Tags proteus simulatorproteus 7.8 windowsLabcenter Electronics
Wed May 12 2021, 06:11 AM
Laurinda
Wed May 12 2021, 05:37 AM
Joann
Does your site have a contact page? I'm having problems locating it but, I'd like to shoot you an email. I've got some recommendations for your blog you might be interested in hearing. Either way, great website and I look forward to seeing it improve over time. get credit report https://freecreditreportww.com
Wed May 12 2021, 04:47 AM
Jenna
This paragraph will help the internet people for creating new weblog or even a weblog from start to end. Credit Report Online https://creditscoresws.com
Wed May 12 2021, 03:37 AM
Tanja
This article is actually a nice one it assists new the web people, who are wishing in favor of blogging. credit report https://creditreportsww.com
Guests: 97, Members: 0 ...
