Discussion in "General help Guidance and Discussion" started by    daemotheo    Jan 20, 2010.
Wed Jan 20 2010, 09:29 am
we're currently doing our project and we are being bugged by our stepper motor... we had seached the net for necessary files, including datasheets and wiring diagrams, but none had helped us.... we're using a 5.1V 1A 200S/R Stepper motor with 6 wire leads......we connected it to a circuit driver, checked and rechecked every component for so many times, yet WE CANNOT MAKE IT TURN!!!!!
HELP US PLEASE.....anyone.
Wed Jan 20 2010, 11:15 am
have you identify leads?
1a ,1b, 2a,2b
Hope following link will helpful for you.
http://www.embeddedcraft.org/steppermotor.html
Gurpreet Singh
Wed Jan 20 2010, 10:04 pm
See if this helps you out:
 shyam like this.
Tags stepper motor wiringstepper motor connectionBLDC motor connection
Thu Jan 21 2010, 03:16 am
Read the stepper motor tutorial in the Tutorials forum.
If you are still stuck, post your circuit diagram.
Give as much information as possible, about what you have done
and what happened.
Thu Jan 21 2010, 07:12 am
to Gurpret312:
=>yes, we had identified the leads from the datasheet of the stepper motor.....
=>thanks for the link, it's not much of a help though cause we had the same info from various sites.
to DavesGarage and ExperimenterUK:
+thanks for the info..... but we're still stuck.... here is the schematic we used....with A -> A+ (white/green), B->A-(green), C->B-(red), and D->B+(white/red)....that's the last combination we used...we even tried moving three leads, keeping one lead on place, using different combinations but still, NOTHING HAPPENS....
Thu Jan 21 2010, 11:24 pm
Full article
http://home.cogeco.ca/~rpaisley4/Unipolar.html
Start by removing the motor and replacing each coil with an LED
and resistor.
Then..
Does D1 flash at a sensible steady rate ?.
Do the four test LEDs turn on and off one at a time and in order ?.
Fri Jan 22 2010, 03:21 pm
Sun Jan 24 2010, 12:13 pm
a new idea just came in....i was told that - "maybe we are not generating enough current to run the motor" - AND HE'S RIGHT!...now, may i ask anybody who happens to have a current amplifier circuit?.... i had been searching the web but i cannot find anything that we need or maybe i am looking at the wrong place???? anyone??
Sun Jan 24 2010, 09:59 pm
daemotheo
How do you know he is right ?.
The output of a ULN2003 doubled up, should be enough to at least move your motor
although using four power transistors instead,may be better.
Is the five volt supply to the motor able to supply an amp ?.
Just in case the ULN2003 is burnt out.. replace it.. then add LEDs as I suggested.
See what happens.
Please stop using multi coloured text in your posts, some of it is hard to read.
Tue Jan 26 2010, 05:43 pm
TO ExperimenterUK
-we tested the current being supplied to the components....
-ok, we'll give it a try...but how are we going to connect it?....can you give me a schematic diagram? (or if you got a current amplifier circuit, it'll be much better ile)
-NOPE....we just found out recently....(we're newbies.....)
See what happens.
-ok, we'll give it a try....
-ooppppsss......sorry.
one more thing, we connected LEDs to the part where there should be coil(motor), three of them flashed, two simultaneously while the other alternates, one was not blinking though the LED was in good condition, we suspects that the line/connection to the D coil, the one that didn't blink, which was connected to the 74194(specifically pin 13) was damaged....what do you think?
utaletxcyw
Wed Apr 17 2024, 10:21 am
